giladitz
As it was mentioned in this discussion:
https://community.cypress.com/t5/ModusToolbox-Bluetooth-SDK/CYW20819-Braktooth/m-p/288395#M2065
There is an issue from Braktooth for CYW20735 which affects CYW20819 as well (https://community.cypress.com/t5/Security-Bulletin/Bluetooth-Denial-of-Service-Vulnerabilities-Brakt...).
The said patch "will be available in BTSDK 3.2 (available in late Q4 2021)".
My questions are:
1) Will this vulnerability affects devices CYW43353 and CYW4343W?
2) When will a patch be available for devices CYW43353 and CYW4343W, and what form will it take?
Thank you.
DheerajPK_41
750 replies posted 500 likes received 500 replies posted
This vulnerability affects only the Bluetooth Classic.  Are you using these chips for any Bluetooth Classic applications?
-Dheeraj.P.K
DheerajPK_41
-Dheeraj.P.K
Yes, we are using it also with Bluetooth Classic for some applications.
giladitz
Hi @DheerajPK_41,
In case we are using Bluetooth Classic with CYW43xxx, will a patch be available for those devices (CYW43353 and CYW4343W) and what form will it take?
Thank you.
DheerajPK_41
You can get the patched HCD files from us or module vendor. The fixes are currently under validation. Please create a salesforce case or contact our sales team to get the patched firmware.
-Dheeraj.P.K
