Dear Sir,
Please provide the latest data sheet for BT, as below image they are not link to latest data sheet,
for example: CYW20706 support BT5.2 but the data sheet shows BT4.2.
Could you please help to provide the latest data sheet for CYW20706/CYW20719B2/CYW20735/CYW20721B2/CYW20819/CYW20820?
Thank you.
Ryan
Many of the Bluetooth datasheets are in the process of being updated.
For certification status, please use the BT Sig site as the most current source of truth for certification status: https://launchstudio.bluetooth.com/Listings/Search
Hi Michael,
Thanks for response, we would like to know is the CYW solution support AOA/AOD and how to implement? Does CYW solution support long range mode?
Thank you.
Ryan
The AOA and AOD is supported by CYW89820. You need to contact with local FAE/Marketing for details.
Long range mode is not supported yet. It will be supported in the product which is plan to release in the latter half of the year.
