OPTIGA™ Trust M: Metadata
sss_551
Moderator 10 likes received First like received First question asked
OPTIGA™ Trust M provides a number of user-related key and data objects. Each key or data object is identified by its unique Object Identifier (OID) and each object has an associated metadata. Metadata is expressed through various constructed tag-length-value (TLV) objects. Table 1 shows the available tags and access conditions for the objects that are defined in the metadata. The description of each tag is given below.
Table 1 Metadata associated with data and key objects
Tag
Structure definition
Execute
Read
Change
0x20
Metadata constructed TLV object
N.A.
N.A.
Always
0xC0
Life Cycle State of the data or key object (LcsO)
N.A.
Always
Always
0xC1
Version information
N.A.
LcsO<op
Always
0xC4
Maximum size of the data or key object
N.A.
NEV
Always
0xC5
Used size of the data object
N.A.
Auto
Always
0xD0
Change Access Condition descriptor
N.A.
LcsO<op
Always
0xD1
Read Access Condition descriptor
N.A.
LcsO<op
Always
0xD3
Execute Access Condition descriptor
N.A.
LcsO<op
Always
0xD8
Metadata Update descriptor
N.A.
LcsO<op
Always
0xE0
Algorithm associated with key container
N.A.
auto
Always
0xE1
Key usage associated with key container
N.A.
LcsO<op
Always
0xE8
Data object Type
N.A.
LcsO<op
Always
0xF0
(Factory) Reset Type
N.A.
LcsO<op
Always
0x20:
This indicates the start of the metadata.
0xC0:
This indicates the lifecycle status of the object. As shown in Table 2, the four primary states support flexible management of the lifecycle. The four primary states progress only in one direction: from a lower value to a higher value. For example, from initialization (in) to operational (op) state, not vice versa.
The access conditions of the regarded data object are considered as operational (op) and cannot be changed when LcsO is absent.
Table 2 Lifecycle status
Value
Description
00000001
Creation
00000011
Initialization
00000111
Operational
00001111
Termination
0xC1:
This indicates version information of the data or key object. 15 bits represents the version and the MSB bit indicates whether the object is valid or invalid. For example, the object is invalid when MSB = 1 and valid when MSB = 0. The default version is 0x0000, when the version tag is absent.
0xC4:
This indicates the maximum size of the data object which is fixed.
0xC5:
This indicates the used size of the data object. The used length gets updated automatically whenever the object data changes. The used size is maximum, when the used size (Tag 0xC5) is absent.
0xD0:
This indicates the conditions in which the data in the object can be changed. During the integrity protected update, the signature associated with the metadata in the manifest must be verified with the addressed trust anchor that stores the corresponding public key. During the confidentiality protected update, the manifest is encrypted by using AES.
During the protected update with both integrity and confidentiality, the access conditions are combined using AND operator. For example, it can be expressed as follows:
Tag
Length
Value
0xD0
0x07
0x20
0xF1
0xD0
0xFD
0x21
0xE0
0xE8
Confidentiality
Shared secret
AND
Integrity
Public key certificate
0xD1:
This indicates the conditions when the data in the object can be read.
0xD3:
This indicates the conditions when operations such as signature verification and signature generation of the object can be executed.
0xD8:
This tag defines the condition under which the metadata update is permitted. For example, it can be expressed in the following table:
Tag
Length
Value
0xD8
0x03
0x21
0xE0
0xE8
Integrity
During the update of the object metadata, the signature associated with the metadata update must be verified with the addressed trust anchor. For example, 0xE0E8 and the associated (Factory) Reset Type (0xF0) gets applied before the metadata is newly set.
In case no (Factory) Reset Type is given by the current metadata, the update will fail.
0xE0:
This tag gives the algorithm identifier supported by the OPTIGA™ Trust M. The different algorithm identifiers supported are given in Table 3.
Table 3 Algorithm identifier
Value
Description
0x03
Elliptic Curve Key on NIST P256 curve
0x04
Elliptic Curve Key on NIST P384 curve
0x05
Elliptic Curve Key on NIST P521 curve
0x13
Elliptic Curve Key on Brainpool P256 r1 curve
0x15
Elliptic Curve Key on Brainpool P384 r1 curve
0x16
Elliptic Curve Key on Brainpool P512r1 curve
0x41
RSA Key 1024 bits exponential format
0x42
RSA Key 2048 bits exponential format
0x81
AES key with 128 bits
0x82
AES key with 192 bits
0x83
AES key with 256 bits
0xE2
SHA 256
0xE1:
This tag specifies the different key usage supported by the OPTIGA™ Trust M. The key usage identifiers supported by the OPTIGA™ Trust M are provided in the Table 4.
Table 4 Key usage Identifiers
Value
Description
0x01
Authentication
0x02
Encryption, Decryption, Key Transport
0x10
Signature Calculation / Verification
0x20
Key Agreement
0xE8:
This tag specifies the data object type. Different data object types and their corresponding values are provided in the Table 5.
Table 5 Data object types
Value
Description
0x00
The Byte String data object type is represented by a sequence of bytes, which are addressed by offset and length.
0x01
The Up-counter data type implements a counter with a current value which can only be increased and a threshold terminating the counter.
0x11
The Trust Anchor data type contains a single X.509 certificate which is used in various commands requiring a root of trust.
0x12
The Device Identity data type contains a single X.509 certificate or a chain of certificates such as TLS, and USB-Type C which was issued to vouch for the cryptographic identity of the end-device.
0x21
The Pre-shared Secret contains a binary data string which makes up a pre-shared secret for various purposes, for example, FW-decryption.
0x22
The Platform Binding contains a binary data string which makes up a pre-shared secret for platform binding. For example, used for OPTIGA™ Shielded Connection.
0x23
The Protected Update Secret contains a binary data string which makes up a pre-shared secret for confidentiality protected update of data or key objects. The maximum length is limited to 64 bytes, even if the hosting data object has a higher maximum length.
0x31
The Authorization Reference contains a binary data string which makes up a reference value for verifying an external entity authorization.
0xF0:
This tag defines what happens with the object data in case of updating the metadata. Table 75 in the Solution reference manual gives different values for the Metadata Update Identifier.
Metadata sample for commonly used access conditions with inference is given in the following table:
Tags
Conditions
Inference
0x20, 0x11
TL metadata TLV-Object
Start of metadata object
0xC0, 0x01, 0x03
TLV LcsO = in
Lifecycle status of the object is in initialization state
0xC4, 0x01, 0x8C
TLV max size = 140
Maximum size that object can use is 140 bytes
0xC5, 0x01, 0x0A
TLV used size = 10
Occupied size is 10 bytes
0xD1, 0x01, 0x00
TLV Read = ALW
Reading the data in the object is always
0xD0, 0x03, 0xE1, 0xFC, 0x07
TLV Change = LcsO < op
Writing to object is possible only if LcsO is less than 7
Note: In case any access condition is absent, the regarded access condition is defined as NEV(Never).
