I have not been able to fix the error "MQTT connection failed with error code 0x8060009 ..."
I am implementing the mtb-example-anycloud-mqtt-client with the Mosquitto broker in MQTTS mode. I have tried it from a Raspberry Pi 3B +, Jetson nano, and an Ubuntu PC. No positive results.
If there is any way to implement it in non-secure mode that would also be helpful
I followed the instructions on Github .. I have created the keys and the TLS / SSL certificates. I have also adjusted the mosquitto.conf file as follows:
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.gz
pid_file /run/mosquitto/mosquitto.pid
persistence true
persistence_location / var / lib / mosquitto /
log_dest file /var/log/mosquitto/mosquitto.log
# Config file for mosquitto
connection_messages true
per_listener_settings true
listener 8883
require_certificate true
use_identity_as_username true
allow_anonymous false
# SSL settings
cafile /etc/mosquitto/ca_certificates/ca.crt
keyfile /etc/mosquitto/certs/server.key
certfile /etc/mosquitto/certs/server.crt
#include_dir /etc/mosquitto/conf.d
password_file / etc / mosquitto / passwd
listener 1883
Help me ... I really want to use Mosquitto in my home project I am using the CY8CKIT-062-WIFI-BT
I have the Modus ToolBox IDE updated in Version 2.31
ModusToolbox AnyCloud SDK
Have you tried with some other broker like AWS? Is the issue happening there as well? If Mosquitto broker is not a hard requirement, please try this with AWS broker.
Aditi
Have you done any changes to the default example?
Aditi
I haven't modified the code, I put entered the WiFi data (SSID, Password), the broker's password and user, and the formatted certificates SSL
".......................................... \ n" \
All following the instructions in the document's .md file.
Aditi
