Measure CO2 When It Matters - Infineon’s XENSIV™ PAS CO2 now comes in SparkFun Red. Check it now!
A-maX
Distributor - Avnet(GC)
First comment on blog 10 replies posted 5 questions asked
Hi,Partners.
What does Parameter-Not operational lifetime meaning? Is that storage temperature?What's the difference between normal operating and Not operational.Thanks.
Krupashankar
500 replies posted 50 likes received 25 likes received
Hi @A-maX,
Presently we don't have the thermal resistance value provided in the datasheet of TLE 4959-U. We have contacted our internal team to get the thermal resistance values.
You could also consider the TLE4998 Datasheet   as a reference for thermal resistance and junction temperature calculation.
Krupashankar
Krupashankar
Hi @A-maX,
Ques: What does Parameter-Not operational lifetime meaning?
Not operational lifetime - When the sensor is not powered or not operating.
Ques: What's the difference between normal operating and Not operational
When the device is powered and operational, the temperature range for normal operation is provided. In Not operational lifetime temperature range is provided when the device is not powered.
Krupashankar
A-maX
Hi,Krupashankar:
     Thanks for your response,as  TLE4959-5U 's operating temperature range is -40 to 175°,max can reach 185°,but in Not operational lifetime temperature range is -40 to 150°,Why is the temperature range even narrower when the device is not working?
Krupashankar
Hi @A-maX,
The operating temperature range is the junction temperature of the device as the device may heat up during the operation, Not operational temperature is the surrounding temperature when the device is not powered so the operating range is higher than the not operational temperature.
Krupashankar
A-maX
Hi,Krupashankar:
    Can we calculate the device junction temperature through Power consumption parameters or there's any other way to get junction temperature? I didn't find any data in datasheet or user manual,Thanks.
Krupashankar
Hi @A-maX,
Krupashankar
