I am trying to implement a "post build step" in my Aurix Project. Anything I put in the Post Build Steps Command, fails when I re-build my project. Pre-Build Steps work fine. The error I get is: "XCP/AurixCAN.d:5: *** target pattern contains no '%'. Stop.". I am running version 1.5.2 of Aurix Development Studio. The post-build step appears to be written to the Make file correctly. Any Ideas or workarounds??
BTW: BuildA2L works just fine from the command line.
if you imported your project using eclipse default "General->Existing Projects" that may cause issues, instead try to import your project using the Infineon Aurix development studio import:
