AIROC™ Wi-Fi and Wi-Fi Bluetooth Combos
hoop4g
New Contributor II
Hello Team Cypress,
My team and I are here to ask you for the best Cypress Wifi module that fits the specification.
The customer wants Wifi module that goes with following details:
- Compliant with wifi-6e standard (bandwidth : 6GHz)
- supports point-to-point method within the distance of 3 meters
- the throughput shall be more than 1Gbps.
If you can share the parts that fits the description and the link to the datasheet that would be amazing.
Thank you for your help and considerations to help!
Sincerely,
Ben.
P.S.
I did part search on my own and found the following
but I would like to confirm with you here
or ask for the better parts.
-CYW55571
-CYW55573
raks_99
Hi Ben,
Both CYW55571 and CYW55573 are tri-band radios. The datasheet for these devices has not been made available to the public community yet. You can get in touch with your local cypress marketing/sales/FAE who can get you access to the datasheets. https://www.cypress.com/about-us/sales-offices
raks_99
Hi Ben,
