AIROC™ Wi-Fi and Wi-Fi Bluetooth Combos
fatFISH
New Contributor
Dear all,
What command can I set the CYW4373 in PSM and the PSM's setting can I change?(like Beacon interval)
Where the CYW4373's user sheet can I got some advices?
Hong
raks_99
Hi @fatFISH ,
Are you looking for wl commands to change Beacon Interval?
Let me look if there is a command supporting that.
raks_99
Hi @fatFISH ,
While using hostapd, you can use the "beacon_int=100" parameter to set the beacon interval. This value can be anything from 15-65535.
Reference: https://w1.fi/cgit/hostap/plain/hostapd/hostapd.conf
fatFISH
New Contributor
Dear raks san,
Thank you very much,it is very useful for me realized that PSM can be setted.
And could you please tell me how to sent the hostapd file?(setting-file download to CYW4373)
I am sorry it may not be a hardly question,but if have the user guide will be helpful.
We will do the excerise to verification,
But from your point of view, can adjusting beacon interval effectively reduce power consumption?
Thank you for your help,
Hong
raks_99
Hi Hong,
Hostapd is a userspace daemon for creating a Access Point . The hostapd.conf file is a configuation file for hostapd. It will remain in the userspace (It will not download to the radio 4373).
https://w1.fi/
Adjusting the beacon interval might not significantly reduce power consumption.
Can you tell me the host that you are using?
I have attached the user guide for Linux-based hosts.
