MingHBK
Distributor - Weikeng(GC)
50 sign-ins 10 replies posted First like received
hi
1. as the description on datasheet, if I wnat to calculate the current comsunption when cyw43012 in doze mode . I need to add the all of "leakage current " with all off ldo (such as BTLDO/RFLDO/CLDOMEMLPLDO ... etc) for total ?
2. what register that I have to set "0" when I want to let system in Doze mode? WL_REG_ON = 0 & BT_REG_ON =0 or more?
3. CYW43012 support DS0 for sleep mode only . how to calculate the current comsunption when in the sleep mode?
thank you .
YashM
50 solutions authored First question asked 250 sign-ins
Hi
May I know, if you are using Linux/Wiced/WHD?
3. CYW43012 supports DS0 for sleep mode only. how to calculate the current consumption when in the sleep mode
A. Please probe the Vbat to get the current consumption.
MingHBK
hi YashM
the OS is FreeROTS.
for probe VBAT to measure current consumption.
sorry , its estimating/planing status . so no PCB can be measurment .
if I want to extimiate current consumption at DS0 mode(DOZE mode) . how to do that ?
YashM
Hi
You can look at the following code example - https://github.com/Infineon/mtb-example-wifi-wlan-lowpower on current consumption.
