AIROC™ Bluetooth
HiNa_2357246
Contributor
I know there is Automotive Grade Bluetooth as a IC,
https://www.cypress.com/products/automotive-wireless
But Is there an Automotive Grade module in the CYBT lineup?
BragadeeshV
Hi @HiNa_2357246 ,
Are you looking for BT modules that is automotive qualified? If yes, we don't have any.
If you are looking at standalone BT chips then you can check CYW89820
https://www.cypress.com/documentation/datasheets/cyw89820-bluetooth-50-soc-automotive-applications
Bragadeesh
BragadeeshV
Hi @HiNa_2357246 ,
Bragadeesh
HiNa_2357246
Contributor
Hi @BragadeeshV ,
Thank you for the reply.  Yes, I am looking for BT module for automotive qualified.
