we suggest infineon bluetooth chip as module agent company.
They want to know whether bluetooth stack can be customized in case that they want to change some value in API.
If it is possible, They want to set the infineon bluetooth products as their own product line
- BT stack
Hi Daniel,
The Bluetooth Firmware which resides in chip ROM is not changeable. If you are talking about the stack, then also there are quite many restrictions as it will directly affect the ROM FW. Very few changes can be done in the stack.
Hi Daniel,
