We are evaluating the CYBT-343026-01 module for a Bluetooth audio application.
When using the Project Creator to create an initial project for the CYBT-343026-EVAL board none of the Audio Examples appear.
When selecting the CYW920706WCDEVAL board (that uses the same processor) I do see the audio examples, does this mean that audio applications are not supported on CYBT-343026-01?
ModusToolbox General
Hi @sbra ,
Try selecting CYW920706WCDEVAL while selecting project and then change the target board using Library manager. Also, make sure you have correct target device in makefile.
When following your instructions I get the following error
makefile:401: *** TARGET CYBT-343026-EVAL not supported for this application. Edit SUPPORTED_TARGETS in the code example makefile to add new BSPs. Stop.
When adding CYBT-343026-EVAL to the SUPPORTED_TARGETS to the makefile I get the following error
*** Build support for the target device not found. Run "make getlibs" to ensure all required build and code dependencies are present.. Stop.
It seems the Library Manger is already calling make getlibs and when I try to run it manually I get:
/bin/bash: which: command not found
/bin/bash: cat: command not found
/bin/bash: grep: command not found
= Importing libraries =
/bin/bash: C:/<user_dir>/ModusToolbox/tools_2.3/make-1.5.0/getlibs.bash: No such file or directory
make: *** [C:/<user_dir>/ModusToolbox/tools_2.3/make-1.5.0/getlibs.mk:126: getlibs] Error 127
