SeunghanLim
Level 5
Level 5
Distributor - Changnam (South Korea)
250 sign-ins 50 replies posted 50 questions asked
Hi!~
My name is Daniel Lim
I tried to make demo with sample application 'Audio Sink".
I already succeded to make a sound with CYW920706CDEVAL kit.
But when I move sample application to CYBT-343026-01 EVAL workspace, updated library, modified target and
downloaded firmware by Modus IDE tool, I failed to make sound with Mobile
I found that GPIO pin can be multi functioned in guide document.
But I don't know how to configurate GPIO Pin to I2S pin.
It may be not tthat issue, But I have doubt of it.
please let me know how to make it sound with CYBT-343026-01
Many Thanks
BRS
Daniel Lim
Could you try to comment the define AUDIO_MUTE_UNMUTE_ON_INTERRUPT.
Owen_Zhang123
5 questions asked 500 solutions authored 250 sign-ins
It should not be the GPIO configure problem. The I2S pin for both platform are the same.
Could you try it on WICED Studio SDK? https://community.cypress.com/t5/Public-Archive/WICED-Studio-6-2-1-Installer-Windows/m-p/250279. We used to run the demo with the WICED SDK before.
You need to install the platform files when you program the device. https://community.cypress.com/t5/Knowledge-Base-Articles/Platform-Files-for-CYBT-343026-EVAL-KBA2210...
SeunghanLim
Level 5
Level 5
I tried to play music by following as you recommended.
But there is still no sound to come out from speaker.
Do I  have to remove some connection pin (ex : J9 ) ?
I attached the buildlog in wiced studio
Daniel Lim
SeunghanLim
Level 5
Level 5
Or  is there any point which I'm missing?
Do I have to download patchram before playing?
Daniel Lim
SeunghanLim
Level 5
Level 5
I commented define value like as below.
But the result is same as well.
  //#define AUDIO_MUTE_UNMUTE_ON_INTERRUPT
I attached graph images.
PCM_OUT is quite suspicious.
Daniel Lim
