Hi All,
Im having the board
https://www.infineon.com/cms/en/product/evaluation-boards/tlv493d-a1b6-ms2go/trying to read data from different MCU's.
I downloaded the example code and , ported to my micro (cortex m4) with I2C driver implementation.
I2C with 400K bps,
PIN 1 - Used for Powering the Sensor
PIN 2 - SCL
PIN 3 - SDA
I initialized the sensor , with SCL, SDA as LOW while power up and sends I2C read commands , with slave address as 0x35
getting response as All 0XFF .
Also i looked these arduino driver examples ->
https://github.com/Infineon/TLV493D-A1B6-3DMagnetic-Sensor/blob/master/src/Tlv493d.cppTried all way but i gets only 0xFF all the time.
Ashok R
