May 12, 2022
06:30 AM
May 12, 2022
06:30 AM
Hey!
I am designing a 48V/8A BLDC motor controller. I have left the PFC pins (PIN44, PIN43, PIN12, PIN21, PIN22, PIN20, PIN19) unconnected since I am powering the controller from a battery pack. While programming using the MCE wizard, there are questions relating to PFC. What should I be doing here?
Labels
09:38 PM
May 12, 2022
09:38 PM
Hi @cw2611,
If PFC is not being used you can disable PFC by writing bit[0] of FeatureID_selectH to 0 in parameter .txt file to
If PFC is disabled then PFC pins can be left open
Krupashankar
09:38 PM
May 12, 2022
09:38 PM
Hi @cw2611,
Krupashankar
