Hello all
I have a question about using OneEye (or any GUI builder)
I want to interface with an xmc4700 by attaching an arduino screen to the female headers I've soldered on an XMC4700. The plan is to read sensor data from the xmc and display it on a screen. This obviously implies writing code to read sensor data, then display it on a screen.
I looked around and infineon provides a few GUI builders such as SeggerAppWizard, OneEye and emWin. Are these the things to use for this task? I was thinking of using the arduino IDE too with the xmc library, is this possible?
Many thanks 🙂
XMC
There is no gui creation tool available. But you can check-out whether emwin could be used.
https://www.segger.com/evaluate-our-software/infineon/xmc4700-relax-kit/
Vasanth
Vasanth
