tazz
100 sign-ins 10 questions asked 25 replies posted
hi we are getting           undefined reference to `malloc_align'.
code is
void *th_aligned_malloc_x( size_t size, size_t align, const char *file, int line )
void *p;
/* avoid warnings since we are not using these */
file=file;
line=line;
p=malloc_align( size, align); /* file, line );*/
this malloc_align is called at
#if defined( NO_ALIGNED_ALLOC )
#define malloc_aligned(size, align) malloc(size)
#define free_aligned(base) free(base)
#else
#if _MSC_VER
#define malloc_aligned(size, align) _aligned_malloc(size, align)
#define free_aligned(base) _aligned_free(base)
#else
#define malloc_aligned(size, align) ({void *p; (posix_memalign(&p, align, size) == 0) ? p : NULL;})
#endif
Pradeep_PN
250 sign-ins 100 solutions authored 25 likes received
Hi @tazz ,
Greetings from Infineon.
Are you trying to get the output from the UART if yes, then please refer the UART code example which  demonstrates a simple UART communication by printing the "Hello world" message on a terminal and blinking an LED using a timer resource.
Link:  https://github.com/Infineon/mtb-example-hal-hello-world
Let me know if you have any further queries.
Best Regards
Pradeep.
Pradeep_PN
Hi @tazz ,
You have defined  _aligned_malloc(size, align) as malloc_aligned(size, align) but you have used
so can you please  change the   p=malloc_align( size, align);  to  p=malloc_aligned( size, align);
Can you please add  #endif at the end of declarations to end all the initiated if loops.
Hope this helps and kindly let me know if you need any further information.
Best Regards
Pradeep.
tazz
hi , thanks for response  made changes but getting error  "undefined reference to `posix_memalign'  "
void *p;
file=file;
line=line;
p=malloc_aligned( size, align); /* file, line );*/
#else
#if _MSC_VER
#else
#endif
#endif
regards
Pradeep_PN
Hi @tazz ,
We assume the error is coming  because you are trying to use a function that has not been declared. So please include the stdlib standard library into your code.
#include "stdlib.h"  or   #include <stdlib.h>
Best Regards
Pradeep.
tazz
hi #include "stdlib.h" was already attached to this code , but error is still there.
regards
Pradeep_PN
Hi @tazz ,
Can you please send me the entire  code so that we can assist you in a better way and can you please tell us which ide are you using?
Best Regards
Pradeep.
tazz
hi we are uing modus toolbox version 3.0 , code files are attached
regards
Pradeep_PN
Hi @tazz ,
As you have defined many user defined header files, in order to check the project at my end I need all the user defined header files . So can you please send the entire  folder of the project where it contains all the user defined header files?
Can you please share the entire MTB folder of the project.
Best Regards
Pradeep.
tazz
Pradeep_PN
Hi @tazz ,
The above link is not working so kindly attach the compressed folder of the project.
Best Regards
Pradeep.
tazz
please find the attached files
regards
Pradeep_PN
Hi @tazz ,
I had went through the code and found an build error which is  undefined reference to the  posix_memalign error.
This is because posix_memalign is not supported in the ARM GCC you are using .
So instead of posix_memalign use memalign which have the similar functionality.
Replace the following macro present in the th_cfg.h
with
#define malloc_aligned(size, align) ({void *p; p=memalign(align,size);(p==0)? p : NULL;})
Best Regards
Pradeep.
tazz
thank you for your reply error is gone, but on output nothing is coming.
regards
Pradeep_PN
Hi @tazz ,
Best Regards
Pradeep.
