03:02 AM
Nov 28, 2014
03:02 AM
hello, i am testing uart protocol for usic module 1 channel 1 in echo method. but i am getting some unwanted characters in between. there is any need to change the code? can u suggest your ideas plz..
07:42 PM
Nov 30, 2014
07:42 PM
Hi sandhya,
Which device are you using?
Did you configure through DAVE app?
How was your setup?
Does your "echo mode" refer to our "Loop Back mode" where output is internally connected with input?
How was your setup?
02:47 AM
Dec 01, 2014
02:47 AM
hello,
now i am working on xmc4500 controller. While testing uart, i am getting a memory management problem. how to come out from the memmanage handler.
02:58 AM
Dec 01, 2014
02:58 AM
hello jackson,
thanks for giving me the reply
i am working on xmc 4500 and ide is dave.
now i am getting the output.
