Myshelter
10 sign-ins 5 sign-ins First like given
I want to create it as a chip development project for XMC4400F64x512, but when I create a new project in ModusToolbox, I only have the entry for XMC4400F100. How do I create a chip development project on the XMC4400F64x512?
Owen_Su
250 solutions authored 500 replies posted 50 likes received
Hi, @Myshelter ,
    You can create a new application based on KIT_XMC_PLT2GO_XMC4400 first, right click the project, and then use BSP Assistant to change the device. If you don't familiar with the IDE, you can refer to the user guide.
    When you change the device, there will have some conflict coming out, you can click 'edit' and then fix the error.
    If this is your first time using XMC, you can use DAVE. Hope this can help you.
BR,
Owen
Owen_Su
Hi, @Myshelter ,
BR,
Owen
