PatrickB
Hi, i am using a i2c dac converter galvanic isolated with a opto couper. It is not possible the dac send a Acknowledge because it is only one direction possible.  i there a parameter how tell the XMC do not wait for Acknowledge after transmitted data?
Patrick
Aashita_R
50 likes received 100 solutions authored 250 replies posted
Hi @PatrickB ,
As of now, there is no such particular parameter to tell XMC do not wait for acknowledge. However, in case you want to implement I2C without acknowledge, just keep sending data from the master. You do not need to wait for the acknowledge in the while loop. This should work.
Also, as per the I2C specification, I2C slave is supposed to provide an ACK so as to let the master know that the transfer is complete. But in case you want to avoid that, please try the above given action.
Aashita
Aashita_R
Hi @PatrickB ,
Can you please let me know the exact part number which you are using?
Aashita
PatrickB
Hi, i use XMC1302-T038X0064  in my project
Patrick
Aashita_R
Hi @PatrickB ,
Aashita
