Dec 19, 2022
11:12 AM
Dec 19, 2022
11:12 AM
ECAT_PHY_RESET line is between the XMC4800 and Broadcom Ethernet Transceiver. ECAT_PHY_RESET is pulled-down.
I want to hold the PHY (Broadcom Ethernet Transceiver) in reset.
I was able to verify that PHY is reset after running "XMC_ECAT_Disable()".
Is XMC_ECAT_Disable() the right away to reset PHY or is there a better way to reset PHY?
GPIO operations did not reset PHY.
Please advise. thank you in advance.
thank you,
- PHY reset
09:14 PM
Dec 20, 2022
09:14 PM
Could you refer to this thread.
https://community.infineon.com/t5/XMC/XMC4800-ECAT-SSC-Enable-reset-request/td-p/310215
EtherCAT slave module can trigger a reset requestin this. Or are you looking to reset only the PHY?
Vasanth
