hold PHY in reset
senx0011
10 sign-ins 5 questions asked 5 sign-ins
ECAT_PHY_RESET line is between the XMC4800 and Broadcom Ethernet Transceiver. ECAT_PHY_RESET  is pulled-down.
I want to hold the PHY (Broadcom Ethernet Transceiver) in reset.
I was able to verify that PHY is reset after running "XMC_ECAT_Disable()".
Is XMC_ECAT_Disable() the right away to reset PHY or is there a better way to reset PHY?
GPIO operations did not reset PHY.
Please advise. thank you in advance.
thank you,
Vasanth
Could you refer to this thread.
https://community.infineon.com/t5/XMC/XMC4800-ECAT-SSC-Enable-reset-request/td-p/310215
 EtherCAT slave module can trigger a reset requestin this. Or are you looking to reset only the PHY?
Vasanth
ncbs
500 replies posted 50 likes received 250 sign-ins
Hi @senx0011 ,
The thread was locked due to inactivity for a long time. You can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Nikhil
