Tim_Shih
250 sign-ins 50 replies posted 50 questions asked
Dear Receiver,
Please refer to the attached file. I follow the step 1. 2. 3. and 4 to build a DAVE simple main project.
it's a very simple project but compiler fail.
Have you ever seen this kind of error messages ?! Could you help me to check it ?!
Thank you so much.
Rodrigo_RT
Level 4
Level 4
50 sign-ins 10 likes given 25 replies posted
Hi Tim_Shih
I believe that your .metadata folder has some corrupted files.
Close Dave, delete the .metadata folder from your workspace.
Restart Dave after deleting the .metadata folder.
Your Workspace will start empty.
Import the projects that are in this file, so you will generate a new .metadata folder, I will be working properly.
Compile each project again to have the files attached to the .metadata folder
Rodrigo_RT
Level 4
Level 4
Hi Tim_Shih
