Jul 29, 2015
04:24 AM
Jul 29, 2015
04:24 AM
I am testing hardware floating point option(-mfloat-abi = hard) on xmc4500(relax lite kit v1). Dave ver: 3.1.8.
I am implementing the following steps:
1. Configuring project as per "DAVE TIP of the day: Things need to do when use math functions".
2. library file used: "libarm_cortexM4lf_math.a" with path: "C:\DAVE-3.1.8\DAVE-3.1.8\CMSIS\Lib\GCC".
3. Compilation error: c:/dave-3.1.8/dave-3.1.8/arm-gcc/bin/../lib/gcc/arm-none-eabi/4.7.4/../../../../arm-none-eabi/bin/ld.exe: cannot find -llibarm_cortexM4lf_math.a
4. Compilation is error free if:
a. "math.h" is used in main.c.
b. "m" is used in libraries option (-l).
c. floating point option is set to -mfloat-abi = softfp.
In short, its ok if I set the "softfp" option.
What could be the problem? Am I missing something.
05:24 AM
Aug 19, 2015
05:24 AM
HI,
You may wish to upgrade to DAVE v4.1.2.
We can now change to 'Full hardware floating point (-mfloat-abi=hard) option under Miscellaneous section of compiler, a similar option is to be selected in Linker-->Miscellaneous --> Floating Point. This feature is added in Dave4.1.2 version.
In general, softfp gives you more compatibility if using external libraries provided not in source code. Hardfp provides you more performance in some circumstances.
Please refer to the following thread:
http://www.infineonforums.com/threads/3185-Full-hardware-floating-point-option
Daryl 🙂
Daryl 🙂
