Jun 06, 2016
03:30 AM
Jun 06, 2016
03:30 AM
I am using ethernetif.c from ETH_LWIP app in my application with freetros. I am experiencing weird response delays on ping. Normally, response time is short 1ms, but occasionally it drops down to 150/200ms. I have noticed that ethernetif.c is using same *buffer* to copy frames from MAC to pbufand oposit in low_level_input and low_level_output functions.
1. Has anyone experienced problems with this design? Can you comment on this...
2. There are two copies [memcpy] of data from MAC to buffer and from buffer to pbuf. Are there any plans to provide more efficient driver design?
3. Which is the latest example of lwip with OS which I can test?
rum
rum
Jun 06, 2016
02:11 PM
Jun 06, 2016
02:11 PM
We have updated the xmc_eth_mac peripheral library and the ethernetif.c. The intermediate buffer is removed.
The updates will be available in end of July in the next release.
In the mean time find attached a beta version not fully tested. Any feedback is welcome.
04:34 PM
Jun 06, 2016
04:34 PM
Hi Jesus,
Thank you for response and project. I have few questions.
1. Why do you always change eternetif? (especially low_level_init function and others) There are numerous versions I downloaded from Infineon website, apps, projects etc... over two years.
2. Where is the description of solved problems and new features?
3. By quick look at code I see that buffer is removed, but library memcpy has been replaced by some assembler code, why you don't use DMA?
4. When contacting experts from lwip about my problem their answer was that there is a problem in vendor driver (and they were right, you made some improvements in latest lwip app as compared to previous) I will see how this one goes and I will post the result.
rum
rum
Jun 07, 2016
03:37 AM
Jun 07, 2016
03:37 AM
Hi Jesus,
Your project has exactly same problem with ping as mine. Let the ping run forever -t switch, wait about 1min, delay in response appear as in the attached picture.
rum
rum
05:27 AM
Jun 07, 2016
05:27 AM
very interesting. May I know how did you send out ping command continuously in cycle?
Jun 07, 2016
08:29 AM
Jun 07, 2016
08:29 AM
Jun 07, 2016
03:48 PM
Jun 07, 2016
03:48 PM
I am testing on hexagon4400. I will send you entire project by a private message if you enable it. Thanks.
BTW in your project you have some mix of libraries versions.
rum
rum
Jun 08, 2016
04:31 AM
Jun 08, 2016
04:31 AM
Hi rum,
You should now be able to send me the project.
Yes, the project I sent is based on XMClib 2.1.6 where some drivers has been modified.
