NarendraC
5 questions asked First solution authored 5 sign-ins
My project doesn't have startup file, project is executed as a function from boot code which is runned through RAM.
We need to install ISR vector address manually  using NVIC_SetVector API.
I am facing like "USIC2_3_IRQHandler' are undeclared .
Kindly help in resolving the issue.
Vasanth
What XMC device are you using ? Will you be able to share your code snippet to recreate the issue at our end ?
Vasanth
ncbs
500 replies posted 50 likes received 250 sign-ins
Hi @NarendraC ,
The thread was locked due to inactivity for a long time. You can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Nikhil
