XMC™ Forum Discussions
FeAs_4655086
10 replies posted 10 questions asked 10 sign-ins
Having problems simulating CCU8 shadow register pwm update with design.infineon.com online simulation tool.
User12775
First like received
The
problems
are
what?
What
are
the
problems?
FeAs_4655086
After updating the compare register. The corresponding pwm signal does not reflect changes.
jferreira
First like received 750 replies posted 500 replies posted
Did you request the shadow transfer using the GCSS register?
Look to function XMC_CCU8_EnableShadowTransfer()
FeAs_4655086
Used Charger.ccu8_module_ptr->GCSS= 0x1. Charger being the renamed instance label.
Feyi
FeAs_4655086
The PWM updates outside the interrupt routine but not within the Compare Match Routine that is called when Compare Register 2 Matches When Counting Up.
FeAs_4655086
Has CCU8 peripheral simulation been implemented on design.infineon.com? I tried simulation on Keil and found CCU8 simulation has not been implemented.
Feyi Asgill
For example 'XMC1300 LED Current Controller Explorer - Example A3' uses CCU8 .
FeAs_4655086
If i am not mistaken. The example quoted uses the brightness and control unit not CCU8. I am talking about CCU8 using Compare Register or Period Register Interrupt implementation.
Feyi Asgill
This example uses BCCU and CCU8.
