09:19 AM
Sep 20, 2015
09:19 AM
Hi there,
I have tried default parameters but DAVE showed an error message. Here a simple code example:
int mult(uint32_t x,uint32_t y=1)
return x*y;
Has anybody an idea what's wrong here?
thanks in advance
return x*y;
thanks in advance
08:11 PM
Sep 20, 2015
08:11 PM
What error message did you see?
If the value of Y is known, than it should not be as the function input.
int mult(uint32_t x)
return x*1;
return x*1;
11:43 PM
Sep 20, 2015
11:43 PM
thanks for quick response,
the second parameter y is meant as default parameter, that means that it is optional when calling the function. In this case y would default to 1.
I use it convenienty with other c++ compilers and documentation is also found in the internet.
By the way, where can I find documentation on the c++ compiler used by dave?
