Bandarikarthik
25 replies posted 100 sign-ins First like given
Hello all,
I am using XMC1302 MCU While Flashing HEX File I have seen the Error I have attached the file with Errors Which I have Observed
Tried with J-Link software, XMC Flasher, DAVE IDE to Set and Get BMI value I cant understand why these Errors are coming
suppose  I have 5 MCU with XMC1302 in these only 3 were programmed successfully remaining 2 are getting Errors
The Proper VCC is also Given to MCU XMC1302 my Custom Board
Its a serious Issue I need to Sort this ASAP... I need the solution ASAP!!!!!!!!
Thanks & regards
    Karthik
Bandari Karthik Kumar
Vasanth
Have these boards been changed to use SWD1(instead of SWD0) in any of the tests you have done ? You can use external wires to short those pins (P1.2 and P1.3 with P0.14 and P0.15 respectively) and try changing the BMI again on these boards.
Vasanth
Vasanth
Vasanth
