06:10 AM
Sep 30, 2016
06:10 AM
Hi I am new to this field of study.
I am using xmc4500 developement board, i.e., I have the hexagonal board and the extension unit.
I also have a rotary encoder (ERN 480 2048 1VPP).
As I connect the USB to the CPU Board, I am able to supply the encoder
with power by connecting the encoder to the extension unit through pin 1 and pin 43. The extension
unit is connected to ACT.
The encoder can generate signals (phase A, B and Z) and I am able to read these using an
oscilloscope (through the corresponding wires).
The question is how can I connect the wires to the development board so that this time
my microntroller can read it. My idea is to read them using uC-Probe
Which pins do i use? And how I do confogure the microcntroller?
I am using DAVE4. I also have the Simulink Embedded Coder Library.
07:32 AM
Oct 04, 2016
07:32 AM
Hi Vryan,
Regarding the Encoder you can have a look to the Application note: AP32289 - XMC1000/XMC4000 - Position Interface(POSIF)
www.Infineon.com/XMC4000 -> Documents
Also can have a look to the forum entry:
https://www.infineonforums.com/threads/3540-XMClib-POSIF-as-Quadrature-encoder-example.
Regarding HW:
For Encoder and Motor Control we have the KIT_XMC44_AE3_00. Or if you already have a XMC4500 CPU card,
you can order KIT_XMC4X_MOT_GPDLV_001. Here you have a device which generate a A/B/Z out of A+/A-, B+B-, Z+/Z-.
http://www.infineon.com/cms/en/product/productType.html?productType=db3a30443cd75eda013cd984f125047e
http://www.infineon.com/cms/en/product/productType.html?productType=db3a304433b8a4100133daf9ddf9112a...
Eric
Regarding HW:
Eric
