I am using XMC4400 to read two analog lines. A timer triggers ADC to read two channels (A,B) and the result events trigger DMA transfer. The DMA transfer for each channel has block size of 512. After few minutes of running the data stops flowing from channel A. I put a counter variable inside DMA_A enevnt handler and the error event count was 2700+(almost half the number of block transfer). The data keeps flowing from channel B though.
My question is: what could cause a DMA error: XMC_DMA_CH_EVENT_ERROR ?
Ali
Hi Vasanth,
Thanks for the reply. I was difficult to share the code due to the complicity of the code and the fact it involves communication with another MCU.
The error was cause by priority conflict with UART interface. Giving global DMA higher priority level solved the issue.
Ali
Hi Ali,
Will you be able to share the project as a zip to recreate the issue at our end ?
Vasanth
Hi Vasanth,
Ali
Hi Ali,
Thanks for sharing the solution with the community.
Vasanth
