MSE
First question asked Welcome!
How to add assembly file to C project in DAVE IDE. Copied the .s file to project but compiler did not compile .s file.
sujatapatil
50 solutions authored 10 likes received 100 sign-ins
Please also check properties tab to include path for assembly files . screenshot is attached for  reference.
Sujata
Giraffe1492
25 sign-ins 25 likes received 10 solutions authored
To add an assembly file (.s) to your C project in DAVE IDE, you need to follow these steps:
  1. Copy the .s file into your project folder.
  2. In DAVE IDE, right-click on your project in the Project Explorer and select \"Refresh\" to update the file list.
  3. Right-click on the .s file in the Project Explorer and select \"Properties.\"
  4. In the Properties window, go to \"C/C++ Build\" > \"Settings\" > \"Tool Settings\" > \"MCU GCC Assembler\" > \"General.\"
  5. Check the box for \"Assemble all files in the project.\"
  6. Click \"Apply\" and then \"OK\" to save the changes.
  7. Build your project. The .s file should now be compiled along with the other files in your project.
Make sure that your assembly file has the correct syntax and is compatible with the MCU GCC Assembler used in DAVE IDE. If you still encounter issues, double-check the build settings and ensure that the .s file is included in the build process.
https://www.infineon.com/cms/en/product/microcontroller/legacy-microcontroller/other-legacy-mcus/dav...
sujatapatil
Sujata
sujatapatil
Hi ,
I have not heard from you since my response. I assume that this is because the issue is resolved and you are busy with other important work.
If, however, the issue is not resolved, please do let me know and I shall work with you to ensure that the issue is resolved.
I will wait for another two days to hear from you. If I do not hear from you, I shall go ahead and close this case.
You can always reopen this case or create a new case for any other issue. We will be happy to help you in resolving your issues.
Thanks and Regards,
sujata
sujatapatil
Hi ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
sujata
