02:36 AM
Dec 04, 2012
02:36 AM
I'm designing a web server with the Hexagon Application Kit and DHCP protocol. In the second example of Infineon web server is possible switch a LED from the internet page, and I would like know how I can write a string from the microcontroller on the index.html to visualize this on the internet page. I know that is possible do this with cgi handlers but I don't know exactly how to do it.
Could anyone show me please how to do it or let me an example?
Thanks in advance.
Thanks in advance.
Dec 10, 2012
02:29 AM
Dec 10, 2012
02:29 AM
Hi Photon,
CGI handlers are used to trigger function execution on the server.
What you need it is SSI Server Side Includes.
To activate this, you just need to activate the appropriate defines. in http.c.
Until now I never tried this but the http.c and http.h are quite well commented so you can start from here.
I would like to prepare a demo like this:
e.g. show the micro-controller temperature in the index.htm.
Unfortunately I am out of office but I should be able to prepare it before Christmas vacation.
I will post it in this thread as soon as it will be available.
Best Regards
Oreste Bernardi
Best Regards
Oreste Bernardi
Thanks in advance.
03:35 PM
Dec 14, 2012
03:35 PM
Dear Oreste,
I'm so gratefull for your help and for your intention of prepare a demo, but I’m working in a research project and would be great make it works before Christmas.
I have been reading the comments of http.c and http.h and examples about SSI but I still need a little help.
I have built the next code but I'm not able to delete all compiler errors.
I don’t know how to use the typedef defined for the handler and in what way build a function for the SSI handler.
If anyone has made SSI code works would be very nice any advice or example to continue working on it.
Thanks for you time.
tSSIHandler SSIHandler;
#define NUM_CONFIG_SSI_TAGS (sizeof{g_pcConfigSSITags} / sizeof{char *});
const char *g_ppcTags[]=
"Hello World",
http_set_ssi_handler(SSIHandler, g_ppcTags, NUM_CONFIG_SSI_TAGS);
typedef u16_t (*tSSIHandler)(int iIndex, char *pcInsert, int iInsertLen
Dec 17, 2012
03:05 AM
Dec 17, 2012
03:05 AM
Hi Photon,
during the weekend I succeed to use SSI in web server. Unfortunately this project is in my home PC and it is done for relax kit.
I will send you my code code this evening when I am at home.
Best Regards
Oreste
Best Regards
Oreste
03:28 AM
Dec 17, 2012
03:28 AM
Hi Oreste,
Thank you for try to build an example. Is not a problem that you have done the project for relax kit it will be helpful.
MagicPhoton
MagicPhoton
Dec 17, 2012
03:10 PM
Dec 17, 2012
03:10 PM
Hi MagicPhoton,
in this forum I can't attach a large file so I can't add my project. (If you send me a direct email I can forward it to you).
However I don't think that there is need.
I guess you already defined enabled the SSI and read the instructions written in the the webserver source code.
#define LWIP_HTTPD_SSI 1
I have put this in the httpd.h
This is my simple handler:
(In this case I don't use the iIndex becasue I have only one tag and in real application I shall use IInsertLen to avoid buffer overflow. (see documentation in source code))
in the main you have to register the handler, for example with this code
the html file shall have extension .ssi (other extension described in the source code are not working because the FATFS is configured only to support filenames with format 8.3 .... only three characters for the extension)
Inside the file you shall use the tag
This is all
Let me know if you have any problem.
Best Regards
Oreste Bernardi
u16_t SSIHandler (int iIndex, char *pcInsert, int iInsertLen) {
memcpy(pcInsert,"Hello",5);
return 5;
static const char * tags[] ={"showtemp"};
http_set_ssi_handler(SSIHandler, tags, 1);
This is all
Best Regards
Oreste Bernardi
04:13 AM
Dec 18, 2012
04:13 AM
Hi Oreste,
I have working a web server with SSI tags. Thank you very much for your help. 🙂
MagicPhoton
MagicPhoton
Dec 21, 2012
01:46 AM
Dec 21, 2012
01:46 AM
Hi MagicPhoton,
I answer here to you post in the microcontroller forum so this will help also other users:
You wrote:
I have already see this behavior by click repeatedly and very quickly multiple times on refresh button.
It seems that this happens much more easily with IE while whith Firefox it is much more rare this problem.
I also found that it is not required to reset the board, but just wait a long time (1-2 mins but I don't remember exactly) and the if the user send another refresh is working fine.
I performed a very fast analysis using Wireshark and I see that IE is sending the a http request then it sending another one without closing the previous opened TCP connection. (http request are sent using TCP protocol), and so the uC is not responding.
I didn't have the time to investigate further but I have a strong feeling that this is related to some timeout or the handling of a double request on the same port.
For example:
Unfortunately I am on holiday I can't investigate further.
Best Regards
Oreste Bernardi
You wrote:
I have programmed the example of WEBSERVER001_Example2 in XMC5400 Hexagon Application Kit but when you switch very fast the LED from the web page, the server stops working and you need to press reset button to restart it.
Could anyone give me any advice to manage the requests and not saturate the server?
MagicPhoton
For example:
- lwip is waiting for close TCP connection packet and if not received it waiting for a long time and then aborting the connection (I have to look for this timeout inside the lwip code)
- lwip should abort a previous connection on the port if it is received a second request on the same port. (I have to check what it is written in TCP spec about this situation)
Best Regards
Oreste Bernardi
01:17 PM
Dec 26, 2012
01:17 PM
Hi Oreste,
Thank you for try to help me with the behavior of switching so fast the LED, I will continue researching on it.
But now I have found another problem more critical in this moment that maybe you or anyone could try to give me an advice.
I have tried to add a graph chart to my web page and everything is working all right when I run it from the local host. However, when I upload the files on the micro SD card of the hexagon board I get an error at the moment that index.htm file calls the javascript. When I look on the source code of the web page I get a red line at that moment (I have attached a screen shot showing it), and the code of the .js file looks different.
I have tried with different Javascript files, I have tried to modify the extensions and the name of those files and always I have a similar error.
Best regards and happy Christmas,
MagicPhoton
MagicPhoton
Dec 27, 2012
02:50 AM
Dec 27, 2012
02:50 AM
Hi MagicPhoton,
could you attach the file that put in the sd card and the one that you get from web browser. I would like to compare it to understand exactly the differences. In fact we used this web browser to transfer also pictures and sounds and we didn't find any issues.
03:53 AM
Dec 27, 2012
03:53 AM
02:02 PM
Jan 09, 2013
02:02 PM
Hi Oreste,
Did you find why is happening this issue when you try to load JavaScript files from the server?
I'm doing something wrong or is that the compiler doesn't support this kind of files?
MagicPhoton
MagicPhoton
Jan 20, 2013
04:34 AM
Jan 20, 2013
04:34 AM
Hi Magicphoton,
I have performed a deeper analysis of multiple led switching.
I have answered in the Dave Forum.
See http://www.infineonforums.com/threads/325-XMC4500-Webserver-slow-response.?p=895#post895
Best Regards
Oreste
Best Regards
Oreste
Jan 20, 2013
04:44 AM
Jan 20, 2013
04:44 AM
Sorry for the delayed answer but I spend one day on not responsive webserver issue:
It should be supported.
I have to prepare an example that involves javascript as well.
Monday I will inform you.
Best Regards
Oreste
Best Regards
Oreste
Jan 20, 2013
01:25 PM
Jan 20, 2013
01:25 PM
MagicPhoton wrote:
Hi Oreste,
MagicPhoton
Hi MagicPhoton,
The example that you sent me use long file names you shall use the format 8.3 see readme of webserver example.
Long filenames option is intentionally not provide to the user because there could be some patent issues. However it is possible to enable it manually at the user responsibility.
I have renamed the files with shorter filenames and I have tried on my relax kit here at home and it is working with Firefox.
In this attachement you can see the modified files
Note: with IE9 the javascript module is not working neither from local pc.
Please let me know if it is working.
Best Regards
Oreste
05:00 AM
Jan 21, 2013
05:00 AM
Hi Oreste,
You are right, the example doesn't support long file names. 😮
The readme.txt file of the example says:
Filesystem supports FAT32 but with filenames should be in the format 8.3.
Filename not longer than 8 characters and extension not longer than 3 characters.
Now is working on Chrome and Safary and is not working on IE9 but is neither working from local PC.
Thank you Oreste,
MagicPhoton
Thank you Oreste,
MagicPhoton
03:07 PM
Jan 30, 2013
03:07 PM
Dear Oreste,
I'm having again problems to make working files on the server, but in this time filenames are not longer than 8 characters.
I have tried to upload this files from local PC and the web page is running properly. The issue is when you load this files from the server, I have tried to call this files one by one from the browser and they have uploaded fine.
Could you try the next files if they run in your server? Do you have any idea of why is this happening?
MagicPhoton
MagicPhoton
Jan 31, 2013
05:11 AM
Jan 31, 2013
05:11 AM
I tried your files and I had the same problem + the system is stalling in loop.
We have just discovered that the ETH004 porting was not done accordingly with lwip wiki guideline.
I don't know if that is the reason. I am investigating this.
Oreste
Oreste
09:44 AM
Jan 31, 2013
09:44 AM
When I tried the files the server went down too. 😞
Tell me something if you solve the lwip issue.
Feb 01, 2013
05:26 AM
Feb 01, 2013
05:26 AM
Hi MagicPhoton,
I have reproduced your issue.
I have done some modification and improvements.
Now the situation is better. I am able to see your graphs.
I will update you today when I clean up the code and make some more experiment.
Oreste
Oreste
06:12 AM
Feb 01, 2013
06:12 AM
Hi Oreste,
That is good news :). I hope you achieve performance improvement with yours experiments.
MagicPhoton
MagicPhoton
Feb 01, 2013
10:21 AM
Feb 01, 2013
10:21 AM
MagicPhoton wrote:
Dear Oreste,
MagicPhoton
Just a test my posting are not added.
09:18 AM
Jul 17, 2013
09:18 AM
MagicPhoton wrote:
Hi Oreste,
MagicPhoton
Hello SSI-Strugglers!
Thank you for this post. I just got it to read out the LED-status dynamically. Wow 😉
Now I added a short HTML-code as described in httpd.h (sending the whole HTML section as a single include). Works.
How can I add more than one tag with the handler via iIndex: u16_t SSIHandler (int iIndex, char *pcInsert, int iInsertLen) ?
I'll appreciate your advices.
05:36 AM
Aug 14, 2013
05:36 AM
Hi CAN,
could you upload your example? I want to display data received via CAN on the web page and I have no clue how to insert dynamic data.
Kind regards
Kind regards
05:50 AM
Sep 23, 2013
05:50 AM
Hello hhh.
Sorry, vacations and spent some time with other projects.
I think we have similar projects - I also need to display dynamic data from the CAN bus.
Here's what I've got so far:
and inside index.ssi there needs to be:
currently I'll update the value at the website via:
// LED1 auslesen und Wert an SSI-Handler weitergeben
char LED_aus[10]="aus";
char LED_an[10]=""; // \"
bool Value=0;
Value = IO004_ReadPin(IO004_Handle0);
if (Value==0){memcpy(pcInsert,LED_aus,10);}
else {memcpy(pcInsert,LED_an,10);}
return 10;
// SSI-Handler gibt Inhalt des Tags an index.ssi weiter
static const char * tags[] ={"Wert"}; // Wert1,Wert2
http_set_ssi_handler(SSIHandler, tags, 1); //2
Die LED1 ist !
01:37 AM
Feb 02, 2015
01:37 AM
Hello, I'm new and I have a question.
Did anyone of you tried to read some data from the webpage and get it into the xmc?
Example: I will change the value of temperature on the website and the xmc should compare it with an given value!
thanks for your help!
Feb 02, 2015
05:41 AM
Feb 02, 2015
05:41 AM
Hi MarV,
This version of software uses lwIP RAW API. Subsequently we shall be introducing a new version using socket connection with RTOS.
http://www.infineonforums.com/threads/1828-XMC_HOT-XMC4500-How-to-create-a-CGI-and-SSI-web-server-wi...
