Hey,
i read the thread "XMCFlasher cannot find the emulator" but can´t replay to this (because it´s marked as solved?!)
How i can setup the J-Link driver for XMC Flasher correct?
I am using the latest version of XMC Flasher (installed over developer Center).
best regards
Andi
XMC
Problem solved:
I installed the J-Link driver with my personal account now:
(it will not work when you install it for "all users")
now i am able to select the Debuggy Type:
everything work fine now.
best regards
Andi
Hi ,
Could you please check the log file and see the error? And make sure that you have installed latest version of segger jlink driver in your system?
Meanwhile old threads are locked once answered. This is to make sure that the threads stay topic specific and user questions appended do not go un-noticed. It is recommended to create a new question in such cases. Even though you can refer the link of the thread if you need to point anything out from an older thread.
Vasanth
Hey Vasanth,
J-Link Version is: V7.60h
LOG:
INFO-com.infineon.XMCFlasher.MainAppController-main: Logger Name: com.infineon.XMCFlasher.MainAppController
INFO-com.infineon.XMCFlasher.SeggerLibLoad-configureLoad: Not Found property: xmcFlasher.JLink.dllPath Searching in registry key
SEVERE-com.infineon.XMCFlasher.MainAppController-start: Failed Segger DLL load
INFO-com.infineon.XMCFlasher.MainAppController-start: Starting Application in process ...
referred to the old thread --> the J-Link driver is installed as admin on my laptop --> the xmc flasher is starting from my personal account could this be the problem?
btw. i cant install anything with my "personal account" (IT restrictions)
best regards
Hi Andii,
Thanks for sharing your solution with community.
Vasanth
