XMCFlasher 1.1.1 Emulator Selection Error
jeg800
First question asked Welcome!
I'm having an issue using XMCFlasher v1.1.1.  There is an error in the log regarding getting the list of emulator connected.  I am unable to select the SEGGER Emulator.  I have an XMCLink connected via USB and have no trouble programming and debugging using the DAVE IDE.
Here is the complete log from XMCFlasher:
INFO-com.infineon.XMCFlasher.MainAppController-main: Logger Name: com.infineon.XMCFlasher.MainAppController
INFO-com.infineon.XMCFlasher.SeggerLibLoad-configureLoad: Not Found property: xmcFlasher.JLink.dllPath Searching in registry key
INFO-com.infineon.XMCFlasher.SeggerLibLoad-configureLoad: Setting property: bridj.JLinkARM.library to: C:\Users\jg\SEGGER\JLink\JLink_x64.dll
INFO-com.infineon.XMCFlasher.SeggerDLL-checkAvailabilityAndLoad:  Loaded JLink DLL 7.84.`
INFO-com.infineon.XMCFlasher.MainAppController-start: Starting Application in process ...
INFO-com.infineon.XMCFlasher.view.RootLayoutOverviewController-handleChangeDeviceName: Setting Device Name configurations
WARNING-com.infineon.XMCFlasher.MikroelectronicaDLL-getListOfEmulator: Error while getting the list of emulator connected
INFO-com.infineon.XMCFlasher.view.RootLayoutOverviewController-handleChangeEmulator: Setting Device Name configurations
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
Before you can use XMC Flasher, you need to install the following software first.
1)Oracle JAVA™ JRE 1.8.0_72 or higher
https://www.oracle.com/java/technologies/downloads/
2) Segger JLINK software 5.12 or higher
https://www.segger.com/downloads/jlink/
2: When you open the XMC Flasher, could you choose the device number which you use?
Could the XMC_flasher can show the connect successfully?
LinglingG_46
