HaadiM
5 sign-ins First reply posted First like given
What do the following defines represent in cyhal_hw_resources.h?
CY_IP_MXSCB_INSTANCES
CY_IP_MXS22SCB_INSTANCES
Also, any one got sample configuration for SPI initialization?
Owen_Su
250 solutions authored 500 replies posted 50 likes received
Hi, @HaadiM ,
    For the definition of the 'CY_IP_MXSCB_INSTANCES', you can refer to the figure below:
    And you can refer to the document below to learn about the SPI setting procedure:
https://www.infineon.com/dgdl/Infineon-AN234127_How_to_use_Serial_Communications_Block_SCB_in_XMC700...
    You can also find the SPI example in ModusToolBox:
    Hope this can help you.
BR,
Owen
Owen_Su
Hi, @HaadiM ,
BR,
Owen
HaadiM
Hi Owen,
Thank you for the response and the resources ... now how do I use the generated code with my application?
Mubeen.
Owen_Su
Hi, Mubeen,
    You can refer to the document below:
    This document provides information about creating applications as well as building, programming, and debugging them using the Eclipse IDE. You can check if this meet your requirements, if not, you can be more specific about your question. Hope this can help you.
BR,
Owen
Owen_Su
Hi, @HaadiM ,
    This thread will be closed due to long time no reply, you can create a new one if you have any other questions. Thanks for your understanding.
BR,
Owen
