Zion
25 sign-ins 5 replies posted First comment on blog
Dear Support Team,
      I 'm use MTB3.1  to debug XMC7200 BSP Samples. I find that the single core sample  can debug successful,but the Multi-core Sample can't enter debuging mode, the error tips is "Could not resolve a value for dynamic variable cy_prj_path" Could you have any suggestion? thanks!
Xmc7000 Issue.jpeg"
Charles_Lai
250 sign-ins 10 likes given 10 questions asked
Have you seen the thread below?
https://community.infineon.com/t5/PSoC-6/Error-quot-Could-not-resolve-a-value-for-dynamic-variable-c...
It's similar to your issue, and it mentioned two methods to solve it. Please have a try first.
Owen_Su
250 solutions authored 500 replies posted 50 likes received
Hi, @Zion ,
    I've tested on my side, I cannot reproduce your problem.
    Have you tried deleting the current project and creating a new one? I've attached the tested example, you can try importing and testing it.
    Hope this can help you.
BR,
Owen
Zion
Dear Owen,
     I have imported you attachment  example and test, but  have the same issue.  My MTB3.1 don't install in default path, i have change the path in common_app.mk.  Do you have any other suggestion? thanks!
Charles_Lai
You can check the Eclipse workspace log file located at <workspace>/.metadata/.log.
You might find the error and its details in it.
If you can't read it, you can upload it here.
hi,
  Sorry i can't understand the log file,Could you help  to check the attechment log file,thanks!
Charles_Lai
