User17511
exploring microcontroller systems for power electronic control
applications I now testing the XMC4800 EtherCAT with DAVE.
After activating the tool chain an run the PWM port toggle example,
I'm looking for standard code examples like:
- direct port access (without PWM)
- timer interrupt configuration and ISR code frame
- ADC configuration and readout
- driving an external DAC via I2C/SPI
Unfortunately the example links on
https://www.infineon.com/cms/en/product/evaluation-boards/kit_xmc48_relax_ecat_v1/#ispnTab4
are looped or dead.
Thanks for your answers.
Ralf
jferreira
10 sign-ins 5 sign-ins First like received
You can either install DAVE4 examples from https://www.infineon.com/cms/en/product/promopages/aim-mc/dave_downloads.html or using the Help>Install DAVE APP/Example/Device Library... and then select Work with: 'DAVE Project Library Manager'.
The XMCLib come with several additional examples, http://dave.infineon.com/Libraries/XMCLib/XMC_Peripheral_Library_v2.1.22.zip.
BTW: In the web site you mention, in the section getting started you can download additional examples.
