krosser
Distributor - Rutronik(GC)
First like given 5 questions asked 10 sign-ins
Hi, IFX
Could you please help provide XMC4800 - Thermal Data?
I have asked such data before:
https://community.infineon.com/t5/XMC/XMC4800-E196K2048-Thermal-Data-R%CE%B8JC/m-p/385505#M11569
Customer want to know if we can provide data of Psi JT  and Psi JB . ( for both MCU :XMC4800E196K2048AAXQMA1  /  XMC4800F100K2048AAXQMA1) .
They wan to make thermal analysis based on the detail data.
Thanks for your help.
Owen_Su
250 solutions authored 500 replies posted 50 likes received
    Sorry for the late reply.
    Unfortunately, we do not have any relevant data about Psi JT/ Psi JB, and all the thermal data related to XMC4800 is already in the datasheet. Thanks for your understanding.
BR,
Owen
Owen_Su
    As the datasheet doesn't provide this thermal data, I need to check with other engineer and then feedback to you. Thanks for your understanding.
BR,
Owen
krosser
Hi,Owen
Thanks for your reply.
Is it possible to get the thermal data before 16th / June?
Owen_Su
    I've raise an iSolar ticket and address it to technical colleagues internally, I will feedback to you once there is an conclusion. Thanks for your understanding.
BR,
Owen
Owen_Su
BR,
Owen
