08:36 PM
Feb 21, 2017
08:36 PM
Any TLS client sample code available for XMC4800 (eval board = KIT_XMC48_RELAX_ECAT_V1) ?
I have tested HTTP_SERVER sample code OK using Keil MDK,
and I added mbedtls package, and use mbedtls ssl_client1.c sample code on github
it seems socket is not included in HTTP_SERVER sample project.
03:21 AM
Feb 28, 2017
03:21 AM
No, the socket API is not included in that demo. Instead a library are provided.
But it should be not very complex to port the LWIP if you need the socket API.
05:51 AM
Mar 08, 2017
05:51 AM
I have compiled mbedTLS and ssl_client1.c sample code onto XMC4800 in Keil MDK,
but still it hangs after it enters mbedtls_entropy_init( &entropy );
Where can I find a working mbedtls ssl_client sample code ?
I am using XMC4800 EtherCAT relax EVB, it has one ethernet port that I am using.
I also saw SharkSSL_Lite in Keil MDK package,
since mbedTLS is not working, should I use SharkSSL ? any sample code available ?
01:16 AM
Mar 10, 2017
01:16 AM
where to find mbedTLS for XMC4800 example?
