Hi
I can't get an Interrupt to work with the XMC4800 Controller.
The rising edge of Pin 0.9 is supposed to trigger the interrupt, please tell me where i am mistaking:
//Setting p0.9 as Input
XMC_GPIO_SetMode(XMC_GPIO_PORT0, 9,XMC_GPIO_MODE_INPUT_PULL_DOWN);
//ERU Config
XMC_ERU_ETL_CONFIG_t eruInit;
eruInit.input_b = ERU0_ETL1_INPUTB_P0_9;
eruInit.edge_detection = XMC_ERU_ETL_EDGE_DETECTION_RISING;
eruInit.enable_output_trigger = true;
eruInit.output_trigger_channel = XMC_ERU_ETL_OUTPUT_TRIGGER_CHANNEL0;
//OGU Config
XMC_ERU_OGU_CONFIG_t oguInit;
oguInit.service_request = XMC_ERU_OGU_SERVICE_REQUEST_ON_TRIGGER;
//ERU and OGU Init:
XMC_ERU_ETL_Init(ERU0_ETL1, &eruInit);
XMC_ERU_OGU_Init(ERU0_OGU0, &oguInit);
//enable Interrupt
NVIC_SetPriority(ERU0_0_IRQn,3);
NVIC_EnableIRQ(ERU0_0_IRQn);
and then my IRQ Handler:
void ERU0_0_IRQHandler(void)
//set breakpoint and be happy when the code arrives here
Do I use the right ERU, ETL, OGU? Is everything configured properly? I read something that I have to call a Method "ClearEventStatus" in xmc4800, but I don't know what could be a valid argument.
Legacy Microcontrollers
Hi @Ricky369 ,
I see that we have resolved the same thread here : Solved: XMC4800 Pin Interrupts - Infineon Developer Community . Can you please refer this and let me know if the solution is helpful in your case or not?
Please feel free to add here in case of any further query.
Aashita
Hi @Ricky369 ,
Aashita
