Sep 02, 2020
08:50 AM
Sep 02, 2020
08:50 AM
Base on the XMC48_ECAT project,
I open SSC to change some of the default parameters of the board.
Vendor_ID I got from Beckhoff, Product_Code=1, Revision_Number=2 etc.
All files are generated, including XML with new values and the eeprom.h with new codes in the array.
But as soon as I run the program over Dave debugger, and connect the board to Twincat, I see the same values as before, just default ones.
It looks like the eeprom was not upload by Dave debug configuration.
How to do this?
How to do this?
04:09 AM
Sep 03, 2020
04:09 AM
Added pictures to illustrate the problem.
Twincat warning message still shows 0x0 for both values when re-run the board from Dave debugger, despite the fact that SSC generated 0x1 and 0x2 in eeprom.h
Sep 03, 2020
06:00 AM
Sep 03, 2020
06:00 AM
I have found how to do this over the Ethernet card, using SSC->Tools.
Can close the thread, thank you )))
