um, I need help.
I want to be able to send data from the Docklight via the UART and store this value in a pointer but I can't get any results like the examples I found. I was able to send to the Docklight via UART_Transmit() but I can't receive anything, not even with interrupts.
I'm trying to implement the examples I found about UART interrupts in the following links:
Example UART INT in youtube and Hello World UART INT example
But I can't get any interrupts as shown in the examples. Am I missing something that is not shown in the exemples or Is there any new resources that is working?
XMC
Hello?????
Hi @user8710 ,
You can refer one such code example XMC MCU: UART Transmit Receive FIFO Interrupts here . This code example demonstrates how to use the Tx and Rx FIFO limit interrupts and send data from the Tx buffer to the Rx buffer. Also, in case you want to refer basic DAVE code examples on UART, please follow this for the basic UART transmit and receive functionality.
Aashita
Hello @Aashita_R,
I saw and tried those examples but still can't receive any information through the Receiver Pin even though I can see the frame with a logic analyser or oscilloscope as I mentioned in this post UART-Can-t-RX-values-XMC4.
Hi @user8710 ,
To avoid any further confusion, I am locking this particular thread. I see that you have created another related thread here : Re: UART Can't RX values XMC4 - Infineon Developer Community . We shall keep the discussion going there. Please post your responses there.
Aashita
HELLO?????
HEYY????
