michael_liao
First like received 5 replies posted 5 sign-ins
This is the official project "D2GL".
The DAC feature is implemented by using the "DAC_LUT" App.
It seems to me that "CCU4_DAC_TRIGGER" is triggered by the "CCU4_PRT_TRIGGER" st event, then "CCU4_DAC_TRIGGER" output the values in the LUT periodically.
The connections as below.
However, the matter in fact is the DAC does not output without calling the "DAC_LUT_Start".
"XMC_DMA_CH_Enable" is called in "DAC_LUT_Start", and it takes a few microseconds.
"XMC_DMA_CH_Disable" is called in "scfmcw_stop" after every LUT cycle, and it takes a few microseconds, too.
(1) Could I enable DMA without disable it anymore?
(2) Could "XMC_DAC_CH_SetMode", "DAC_LUT_ResetIndex" and "DAC_LUT_SetRepetition" are called without disable DMA?
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
1: The first question:
Because when you call the API:
XMC_DAC_CH_SetMode(HandlePtr->module_ptr, HandlePtr->ch, XMC_DAC_CH_MODE_IDLE);
It means the DAC module has been disable. So it calls the "DAC_LUT_Start(p_inst->mDAC_LUT);", it enables the DAC module.
2:The second question:
The DAC_LUT_Start()  enables the DAC channel. It takes the code running time.
3: From the code comments, I think we should ensure to reset everything before the new frame. So I think we should design the code depending on the code example.
More about the Timing flow implementation in firmware:
4: More about radar sensor firmware, please refer to the linker:
https://www.infineon.com/dgdl/Infineon-Distance2GoL_Software_User_Manual-UserManual-v01_01-EN.pdf?fi...
LinglingG_46
