XMC™ Forum Discussions
tngynghui
First solution authored 10 sign-ins 5 sign-ins
Hi, I use XMC4500 RelaxKit to develop Eth_LwIP ,but after add eth_lwip to project successfully,  I find the eth_lwip 4.1.18 showing wrong, and I can't set  several parameters. Also, I can run the project, but in the computer, I can ping 168.192.0.10 , but the XMC4500 RelaxKit has no echo. Can you give me some advice, thank you!ETH_LWIP V4_1_18显示异常.JPGXMC4500响应异常.JPG
Spoiler
Spoiler
ncbs
50 likes received 250 sign-ins 250 replies posted
Hi @tngynghui,
Please take a look at the IOT_EXAMPLE_XMC47 code example implemented in XMC4700. Please follow the steps provided in the Readme file.
Nikhil
Vasanth
Kindly share the Dave IDE version you are using? Additionally the source from which you have taken the example project too.
Vasanth
tngynghui
hello,Vasanth,
I have use DAVE IDE version 4.5.0,it is the latest version.  I also use  DAVE version4.4.2 to test eth_lwip 4.1.18 , and get the same result. Can you test the example, and show me the reason. Thanks
tngynghui
tngynghui
hi,
thank you very much for your reply. I want to find a whole example about eth_lwip app with XMC4500 to tansmit data, who can give me  some advice or a few example?
tngynghui
ncbs
Hi @tngynghui,
Nikhil
tngynghui
Hi,@ncbs,
I only have XMC4500 relaxkit,  and I'm sorry I am not familiar with XMC47 . Can you help me to test the example for xmc4500? Thanks.
tnynghui
