06:07 AM
Feb 17, 2015
06:07 AM
I tried to run the Webserver XMC4500 relaxKit example inside DAVE3 (Version 3.1.10) for XMC4500 relax Kit V1. Build and debugging works well. But it is not possible to use the Ethernet.
I checked the settings by using the Webserver Quick Start document. Everything seems ok.
I used the settings for manual IP.
I used a direct connection to notebook with crossover cable and tried also a connection with patch cable on a switch. The notebook works with Windows XP
Any ideas?
Any ideas?
