12:25 AM
Mar 03, 2016
12:25 AM
I got following problem. I'm new to XMC4500 and Dave4. I'm woriking on a bootloader. The Bootloader resides in sector 0 and 1. The Bootloader will load via a windows program the new hex file into the flash.
What I want to know is how can I define an offset for the hex file which should be loaded into the flash by the bootloader?
I tried editing the linker file
FLASH_1_uncached(RX) : ORIGIN = 0x0C004000, LENGTH = 0xFC000
but this wont compile. How can i make the program to start at location 0x0C004000 ?
thanks for your help.
12:32 AM
Mar 03, 2016
12:32 AM
I did this on my software for both cached and uncached. Please give this a try.
FLASH_1_cached(RX) : ORIGIN = 0x08040000, LENGTH = 0x100000
FLASH_1_uncached(RX) : ORIGIN = 0x0C040000, LENGTH = 0x100000
12:40 AM
Mar 03, 2016
12:40 AM
Thank you Travis. It worked.
01:09 AM
Mar 03, 2016
01:09 AM
I wanted to add something for other people that maybe searching for something similar.
I chose the address 0x0C004000 because of the erasing which can only be done sectorwise (See reference manual 8-5 under "features" and 8-7 under "PFLASH").
