02:24 AM
Sep 08, 2015
02:24 AM
I had used WEBSERVER001 in Dave 3 to send data to the webserver using SSi handler. I studied the example "xmc4500_relaxkit_lwip_httpserver_netconn" in order to understand how to deal with webservers in Dave 4. However, I could not find anything related to ssi. Can you please send any example about ssi or any other tool to send data from XMC4500 to a web server.
Can I save the webserver file(index.html or index.ssi) in the SD card and use it as I did in Dave 3??
Thanks and Regards
Thanks and Regards
Sep 15, 2015
07:49 PM
Sep 15, 2015
07:49 PM
You can refer to this example which has got Common Gateway Interface (CGI) and Server Side Include (SSI).
http://www.infineonforums.com/threads/1828-XMC_HOT-XMC4500-How-to-create-a-CGI-and-SSI-web-server-wi...
Sep 15, 2015
08:02 PM
Sep 15, 2015
08:02 PM
01:03 AM
Oct 07, 2015
01:03 AM
I still have have the same problem. The "project has been created with older DAVE version (<4.0.0)"
It did not solve the problem
Thanks 🙂
Thanks 🙂
Oct 07, 2015
02:55 AM
Oct 07, 2015
02:55 AM
Currently I have not done one with DAVE4 yet.
