I'm looking for the ADC channel event interrupt enable flag. I've found similar for result event (GXRCRy.SRGEN) however I don't see the similar enable flag for the channel event. Channel event raised for example fast compare.
Hi @jsmith678x.,
Could you please check out CHEVMODE of GxCHCTRy in page 19-97 of XMC4500 Reference Manual? When CHEVMODE = 00, a channel event is not generated.
Nikhil
Hi @jsmith678x.,
Nikhil
In my case CHEVMODE is not zero
No
Hi @jsmith678x,
Could you please elaborate on your response?
Are you able to change the CHEVMODE or are you not seeing any change in functionality when CHEVMODE is changed?
regards
Nikhil
