amanning
Level 4
Level 4
25 replies posted 10 questions asked 25 sign-ins
Is there an example program for the XMC using the USB in Host Mode? There is nothing shown in the list of µVision packs.
I am using the XMC4500, but an example for any of the XMC family would be helpful.
My aim is to connect a barcode scanner or keyboard to the XMC.
sujatapatil
10 likes received 100 sign-ins 25 solutions authored
Hi ,
There are two ways you can use USB host driver
1>You can add USB host module using USBD_VCOM in DAVE, this will add manifest for both host side and device side  and USB driver will be placed in Dave generated code . Screenshot is attached.
2> please use one of the code example link provided above . USBD will be imported as library in this example . For your request where you want to use HID devices please use  USBD_HID_XMC47 example code . This will have usb host driver and  HID class driver .
 XMC4500 USB can run in Low-speed host mode : Yes. XMC4500 USB is 2.0 compliant and backward compatible.
Please let me know if it help you or you need further detail.
Sujata
sujatapatil
Hi ,
You can find example code USB host and HID class at below location,
https://www.infineon.com/cms/en/product/promopages/aim-mc/dave_downloads.html
Sujata
amanning
Level 4
Level 4
The link you gave has a lot of examples, but I could not find a USB Host example for HID.
I want to connect a barcode scanner or keyboard to my XMC4500, so it needs to run as a HID Host.
sujatapatil
Hi
Please find example code  USBD_HID_XMC47 at location https://www.infineon.com/cms/en/product/promopages/aim-mc/dave_downloads.htmlhttps://www.infineon.com/cms/en/product/promopages/aim-mc/dave_downloads.htmlfor HID class implementation .
Please read Getting started Guide in downloaded folder for more information.
Sujata
amanning
Level 4
Level 4
Dave does not seem to have a USB Host module. I can only find USB Device.
Does anyone know if the XMC4500 USB can run in Low-speed host mode?
sujatapatil
Hi ,
Sujata
